This is my first time attempting to backup a DVD. When trying to open my DVD in DVD Shrink, it either says, "data error (cyclic redundancy check)" or "sector encrypted" at 10 percent. How can i fix this? thanx.
Results 1 to 10 of 10
Have you tried ripping with DVD Decrypter and then using DVD Shrink?
Yea, and it said it would take about 50 some hours. I'm using Smartripper right now and it's also going incredibly slow. I juss checked my ASPI layer and it's all good and updated.
When using DVD decrypter, it stops at 10% and gives me this error:
Could this DVD juss be well encrypted? -
... or dirty.
... or less likely, badly authored, either on purpose or by accident. See the thread:
https://www.videohelp.com/forum/viewtopic.php?t=225012.
There are some good suggestions in the thread as to how to decrypt and copy a DVD with authoring errors.
There is some debate as to whether these types of disks are mis-authored on purpose to improve the weak copy protection. -
try cleaning the dvd (of both finger prints and scratches). Toothpaste, automotive polish, Brasso metal polish, etc.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
Problems backing up DL dvds using DVD Shrink and ImgBurn
By ManuBumb in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2009, 21:35 -
Will using the pc while using DVD shrink cause problems to editing????
By jones24 in forum DVD RippingReplies: 8Last Post: 7th Oct 2008, 10:39 -
problems with DVD Shrink 3.2.0.15
By janefield in forum Newbie / General discussionsReplies: 6Last Post: 25th Aug 2008, 07:20 -
dvd shrink problems
By anahata3 in forum DVD & Blu-ray WritersReplies: 9Last Post: 9th Jul 2007, 11:07
