This question was asked of me and I had no info on this because I dont do much recording on rw's, so I thought I would post it for some feedback
Hey, I've been having some trouble with my DVD+RW's lately, and I was wondering if you had any ideas on why this is occurring.
I've been using about 20 different DVD+RW's to record movies until I can watch them and then usually record over them. However I've found that after just a few re-writes, they become useless. When I put them in the computer doesn't even recognize the disc to erase/format/record/play. In addition they tend to form visible little "spots" all over the burning element. They're not external spots as they don't wipe off. Plus, they tend to form in a similar pattern: a group of three larger spots with a lot of small ones scattered throughout the rest of the disc. It's really strange. It's happened mostly with a batch of Memorex discs, but also with a couple of other brands. I'm at a complete loss as to what's happening...any thoughts?
Jeff
Results 1 to 16 of 16
Obviously gremlims are tampering with the fabric of space near your DVD's again. I recomend bug spray with deet to keep them away sir.
Seth
Most likely cheap dvdrw that goes bad faster,i` ve had a few go bad after a dozen erases with spots and bought a better brand with are still going strong after a lot of erases.
I have had plenty go bad on me. All of them Sony branded. Manually doing a full erase does not seem to help either. They are all probably 10 years old. They fail in multiple drives too, so I don't think it's my DVR, since they work badly on my PC as well.
Yes, DVD RW discs can go bad. I'd suggest using Verbatim brand +RW discs.
RW discs are the most likely to deteriorate over time. But good ones can be rewritten hundreds of times before failing -- you're more likely to stop using them because you've scratched them rather than because they've worn out. I have some 10+ year old Verbatim DVD+RW discs (written once) that still read fine. Other's that have been rewritten a few hundred times. I wouldn't buy anything but Verbatim +RW these days.
Some of my failed RW discs are old and only used a few times. No scratches.
In this particular case, yes. The +RW discs are superior. There is an old article on MyCE.com that compares the two and explains the advantages of the +RW format compared to -RW: http://www.myce.com/article/Why-DVDRW-is-superior-to-DVD-RW-203/
Why are you guys replying to a 10 year old grave robbery by zzyzzx?
Just checked the discs, they are ~10-15 year old Sony DVD+RW that are going bad. Some of them were not used much, but some were used a lot.
I suppose I'll have to check my collection of equally ancient DVD+RWs, since I have some "interesting" off-brands of questionable quality. Don't think I've used them since we got the networked WDTV player.
I probably should be checking for a program that can check the disk integrity as well, since I mostly use these in a vintage 2007 Philips DVR (3575 type) which might also be the problem.
VHS-->DVD, "action scenes" and bad sources
By Jdrive in forum Capturing and VCRReplies: 7Last Post: 13th Oct 2010, 00:09 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
Did "Good" media go bad -OR- DVD Recorder conundrum? Help!
By MrCreosote in forum MediaReplies: 9Last Post: 11th Sep 2007, 19:33
