Hi,
I just acquired "WinFast TV2000 XP Expert" and started capturing with ULead Video Studio 7.
There's sound while I'm capturing, but the captured file has no sound when playing.
I tried DVD and DV capturing.
Help!
Pahidla
Hello,
Go to sound proporties and look at your recording sound level screen. Is the line in selected? You may have it on mic. Check with your capture card manual to see if you need it set it to line in or another designation.
Kevin
P.S. It's a good sign the sound is present while recording. If it's not in the final file that should mean your soundcard or capture card isn't set up to record it.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
NO sound when capturing with Ulead SE 11
By TheKillerQueen in forum Capturing and VCRReplies: 41Last Post: 13th Mar 2012, 03:55 -
sound interposition when capturing from tv
By eliqush in forum Capturing and VCRReplies: 0Last Post: 7th Oct 2009, 17:35 -
No sound when capturing video ???
By j4mes_bond25 in forum Capturing and VCRReplies: 6Last Post: 10th Aug 2009, 12:03 -
Capturing Audio in Sound Recorder
By ViRaL1 in forum Off topicReplies: 3Last Post: 2nd Dec 2008, 03:26 -
No sound while capturing from Sony Handycam to PC
By Tony11 in forum Capturing and VCRReplies: 1Last Post: 24th Jan 2008, 23:51
