  1. Hi all,
    Below is the log of one of many failed attempts to get this to work. The mpeg is a TV episode, there are another 2 which I haven't tried. This is what happens, when it is done the muisc is out of sync and the picture freezes for a few seconds on a regular basis. Any help appreciated.
    Gerry
    Starting SVCD2DVD: v1.51.2.0
    Begin time: 22:36:14
    ******** Ripping BIN images to get mpegs (VCDGear -fix)
    Analysing File: G:\test\vol2final_FIXED.mpg
    ++ WARN: packet length beyond buffer (pos = 18 + size = 2030 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
    ++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
    -->Processing 1 mpeg files
    ############### New MPEG File ###############
    Type: VCD
    Horizontal Res: 352
    Standard: NTSC
    Audio SampleRate: 48000
    ******** Demultipexing original mpg file
    bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
    speed increases by, Apachez and Christian Vogelgsang
    Saving stream 0xE0 into file G:\test\vol2final_FIXED_DVD.mpv...
    File G:\test\vol2final_FIXED.mpg is an MPEG-1 Program Stream
    Summary:
    MPEG Packs = 346199
    System headers = 1
    Padding Stream packets = 160, total bytes = 323267
    MPEG Audio stream 0 packets = 29855, total bytes = 60395328
    Video stream 0 packets = 316186, total bytes = 638062128
    Saving stream 0xC0 into file G:\test\vol2final_FIXED-0.mp2...
    Summary:
    MPEG Packs = 346199
    System headers = 1
    (Total size: 767MB, Duration: 00:01:33, Rate(MB/Min): 492.75)
    ******** Resampling audio from 44.1 KHz to 48 KHz
    Skipping....
    ******** Trimming start of video ES
    - Nothing to do.
    ******** Multipexing elementry streams
    INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
    INFO: [???] File G:\test\vol2final_FIXED_DVD.mpv looks like an MPEG Video stream.
    INFO: [???] File G:\test\vol2final_FIXED_DVD.mpa looks like an MPEG Audio stream.
    INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [???] Found 1 audio streams and 1 video streams
    INFO: [???] Selecting dvdauthor DVD output profile
    INFO: [???] Multiplexing video program stream!
    INFO: [???] Scanning for header info: Video stream e0 (G:\test\vol2final_FIXED_DVD.mpv)
    INFO: [???] VIDEO STREAM: e0
    INFO: [???] Frame width : 352
    INFO: [???] Frame height : 240
    INFO: [???] Aspect ratio : 4:3 display
    INFO: [???] Picture rate : 29.970 frames/sec
    INFO: [???] Bit rate : 2028400 bits/sec
    INFO: [???] Vbv buffer size : 229376 bytes
    INFO: [???] CSPF : 0
    INFO: [???] Scanning for header info: Audio stream c0 (G:\test\vol2final_FIXED_DVD.mpa)
    INFO: [???] MPEG AUDIO STREAM: c0
    INFO: [???] Audio version : 1.0
    INFO: [???] Layer : 2
    INFO: [???] CRC checksums : no
    INFO: [???] Bit rate : 24576 bytes/sec (192 kbit/sec)
    INFO: [???] Frequency : 48000 Hz
    INFO: [???] Mode : 3 single channel
    INFO: [???] Mode extension : 0
    INFO: [???] Copyright bit : 0 no copyright
    INFO: [???] Original/Copy : 1 original
    INFO: [???] Emphasis : 0 none
    INFO: [???] SYSTEMS/PROGRAM stream:
    INFO: [???] rough-guess multiplexed stream data rate : 2259600
    INFO: [???] target data-rate specified : 10080000
    INFO: [???] Setting specified specified data rate: 10080000
    INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
    INFO: [???] New sequence commences...
    INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
    INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
    INFO: [???] Scanned to end AU 69874
    INFO: [???] STREAM e0 completed @ frame 69874.
    ++ WARN: [???] Discarding incomplete final frame MPEG audio stream c0!
    INFO: [???] STREAM c0 completed @ frame 104851.
    INFO: [???] Multiplex completion at SCR=226491830.
    INFO: [???] Video e0: buf= 237568 frame=069874 sector=00317352
    INFO: [???] Audio c0: buf= 1792 frame=104851 sector=00029899
    INFO: [???] VIDEO_STATISTICS: e0
    INFO: [???] Video Stream length: 638062128 bytes
    INFO: [???] Sequence headers: 4514
    INFO: [???] Sequence ends : 1
    INFO: [???] No. Pictures : 69874
    INFO: [???] No. Groups : 4514
    INFO: [???] No. I Frames : 4514 avg. size 12719 bytes
    INFO: [???] No. P Frames : 18029 avg. size 11252 bytes
    INFO: [???] No. B Frames : 47332 avg. size 7981 bytes
    INFO: [???] Average bit-rate : 2189200 bits/sec
    INFO: [???] Peak bit-rate : 3180000 bits/sec
    INFO: [???] BUFFERING min 15 Buf max 134306
    INFO: [???] AUDIO_STATISTICS: c0
    INFO: [???] Audio stream length 60394756 bytes.
    INFO: [???] Syncwords : 104853
    INFO: [???] Frames : 104853 padded
    INFO: [???] Frames : 0 unpadded
    INFO: [???] BUFFERING min 15 Buf max 587
    INFO: [???] MUX STATUS: no under-runs detected.
    (Total size: 686MB, Duration: 00:01:20, Rate(MB/Min): 508.80)
    Analysing File: G:\test\vol2final_FIXED_DVD.mpg
    ++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
    ++ WARN: mpeg stream contained no scan information (user) data
    ++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
    ******** Creating DVD Folders...
    Creating VTS #1
    SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    -->: DVDFolders creating VTS
    -->: VTS 01
    STAT: Processing G:\test\vol2final_FIXED_DVD.mpg...
    !!!: GOP is not closed on cell boundary (may be non seamless)
    This below continues for loads more lines:
    WARN: audio sector out of range: 8199 (vobu #1769, pts 82133057)
    WARN: audio sector out of range: 8207 (vobu #1770, pts 82178102)
    WARN: audio sector out of range: 8209 (vobu #1771, pts 82223147)
    (Total size: 686MB, Duration: 00:01:36, Rate(MB/Min): 428.00)
    ============ Complete ============
    ============ Duration: 00:04:31
    This continues for a lot more lines
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    looks like a knackered kazaa download to me.
    Demux the file, convert the video to huffyuv or totally uncompressed if you have the space and conver the .mp2 to uncompressed wave and start again.
  3. Originally Posted by flaninacupboard
    Wasn't a Kazaa it was a long time ago off a newsgroup, works fine as a mpeg. Will try what you have suggested and see if I can manage it. Not having much luck with this program, so far Zero success rate out of umpteen tries
