hey,
i gotta problem when i make xvids to vcd using vdub and tmpgenc. when played on my dvd player the vcd gerks and sometimes plays choppy. this happens with most xvids. sometimes i use the guide here (XVID to DIVX) and the work fine except for the fact that once in a while you see blocks in the vcd. Does anyone else experience this with Xvids? what should i do to encode them to smooth, nice vcd's or what else should i do to convert them to divx before encoding them?
thanks a lot.
Oh Ya,
Does the Four CC changer have anything to do with the blocks that appear in the divx created? i don't use it before using vdub to convert the xvid to divx, should I?
thanks again -
Does it appear the same on your computer as on your DVD player?
"Art is making something out of nothing and selling it." - Frank Zappa -
hey,
i'm sure it does play with the sudden blocks on the computer. it doesn't happen to divx movies i encode, just xvids. you know the guide here that explains xvid to divx conversion? i do that except the avi FOUR CC changer step at the beginning. do you think that is what's causing all this? also, instead of divx 5.1, i use divx 3 because of the guarentee of audio sync and smooth playback. i just dunno how to make a divx out of an xvid that will play like all the other divx.
any thoughts?
thanks again
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 15:00 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 12:36 -
Problem with XVID
By s2dat in forum Newbie / General discussionsReplies: 9Last Post: 2nd Aug 2008, 12:25 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 16:51 -
joining xvid problem
By aerial25a in forum EditingReplies: 2Last Post: 23rd May 2007, 04:14
