    Jul 2004
    Canada
    hello
    I've been encountering problems when backing up my DVD's. The problems were described in another post I'd made as being random pauses and glitches.
    The type of media I was using when I encountered the problem were "MAXELL DVD-R" discs. I've tried various programs, but the result was the same to varying degrees. The errors would range from momentary pauses to the movie all out freezing (to the point that I had to stop the movie, restart it, just to encounter the same problem again).
    Suffice it to say, theres problems.
    I HAVE however, found a partial solution. This is where I need your input.
    When I used "MEMOREX DVD+RW" discs to backup my movies I encountered no problems.
    With that in mind I invested in a 25 stack of MEMOREX DVD-R discs.
    suprise! glitches and pauses.
    Now I am left with several questions.
    What is the actual difference between DVD-R and DVD+R?
    Any ideas why I would encounter problems with one and not the other?
    does the fact that I am using DVD+RW discs made a huge difference (relative to DVD+R)?
    I'd rather not invest in alot of DVD+RW dics if another format will do the same job (At a price thats a little lower).
    The specs are as follows for the tools used.
    p-4 1.77
    256MB RAM
    DVD shrink 3.2
    DVD Decrypter
    Nero smart start (nero express 6)
    Maxell DVD-R
    Memorex DVD+RW
    Toshiba 1800 standalone dvd player
    LG GSA 4120B Supermulti DVD rw
    thank you for your time.
    scratch the surface off a cynic - you will find a disillusioned idealist.
