  1. I have read the stickies and what I could find on ripping a bin image. Those articles are dealing with ripping a movie or something that I would want to burn to a DVD for example. But my question deals with a program that is on a bin file and I want to use that program. Do I use the same process? And actually, I'm not sure which conversion article I would use, so if you could direct me to the right one....
    And, just to be superfluous and repetitive (get the joke? :P )...Are there any steps that are different for a bin image for someone who doesn't want to end up burning that file, but just using the program that comes out of, say, Isobuster?
    Thank you for any help.
  2. Member Grimey's Avatar
    May 2004
    Canada Eh?
    just mount the image with Damon tools and use it from the virtual drive. thats the simplest thing to do.
