I need a good burner that will read DVD-RAM discs. I don't care about recording to RAM, I'll record to DVD-R, I just need to be able to copy from RAM. Most of my discs are double sided, so I need something that is compatible with 9.4 RAMs. I would prefer a burner that would accept the cartridges, but that's not a big deal. Any suggestions would be greatly appreciated.
Results 1 to 15 of 15
I recommend the 16X Lite-On 166S, it can raed any disk you throw at it, be it dvd ram, dvd+r/rw, dvd-r/rw, cdr/rw etc..
ive never have a problem with it.
Also, the fastest drive to rip dvds. -
Sorry, i misread your post, you mentioned a burner, the Lite-On is a dvd rom drive, not a burner.
He said RAM.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
The Toshiba SD-M1712 DVD-ROM drive will read DVD-RAM discs, but it will not read them in a cartridge.
The LG GSA-4082B will read and write to DVD-RAM discs, but again, will not read them in a cartridge. -
If you're going to go LG, why not go all the way and get the GSA-4120B? Dual format, Double Layer and writes DVD-RAM at 5x.
Nothing can stop me now, 'cause I don't care anymore. -
Does anyone out there own the LG drive? Does it perform well? It's looking pretty good from what I can find about it. I don't like the quality of toshiba's products.
Check the reviews in the DVD Writers section.
https://www.videohelp.com/dvdwriters.php?DVDnameid=414&Search=Search&list=0#featuresandcommentsNothing can stop me now, 'cause I don't care anymore. -
Did that, I like everything I've seen so far, thanks for the advice. Has anyone used the LG with prodiscs? That's all I've used lateley, I have alot of them and need something that works with them.
LG ROM drives perform flawlessly.
latest & best, Pioneer 108 does read these.
I don't know if it takes carts though. -
LG GSA-4xxx models read and write DVD-RAM, but so far as I know none of the take cartridges.
My -4082B's are solid, reliable burners, and they burn everything. -
Are the LG and the Pioneer compatible with the double sided 9.4 Ram discs? I can't find anything that says they are or are not. When I was looking into drives a year and a half or so ago I was told the Pioneer wouldn't work on double sided RAM discs.
Editing Panasonic Burner DVD-RAM VRO Video In Computer
By Teshia in forum User guidesReplies: 47Last Post: 18th Feb 2013, 08:06 -
Lite-On Burner Will Not Read DVD+R Media
By kca741979 in forum MediaReplies: 11Last Post: 28th Feb 2010, 01:47 -
DVD Burner sudenly read/writes at less than 1x speed
By Megahurts in forum ComputerReplies: 1Last Post: 22nd Apr 2009, 21:47 -
Cartridge-type DVD-RAM burner and SATA
By Semaphoric in forum MediaReplies: 2Last Post: 22nd Aug 2008, 11:35 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 05:49
