  1. On the last post, I told the story that any 2D application screams on my Nvidia FX5600 256mb card, but all 3D applications (call of duty and doom3) crash to the desktop.
    One poster recommended that my video card was being fidgetty and I should look into another brand...so I reinstalled my old Mx440 64mb to see if it would cure my problems, but I got the same crashing problems.
    I contacted BFG and they sent me a list of items to look at in the bios...went there and double checked everything...they all looked fine.
    after all this...still bad 3D
    But wait...it gets better! Now IE6 crashes almost every time it's opened for a few minutes AND now I get random computer restarts.
    The system temp is sitting at 45c and the cpu temp is 66c
    Checked ENTIRE system with anti-virus and came up goose-eggs.
    what do you think? bad mobo? bad AGP port? corrupted OS?
    As always...thanks in advance...
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Corrupted driver maybe?
    Try downloading a new one, uninstall the driver and reinstall the new one pointing it to the driver, and not using the automatic search
  3. Did that to no avail...
    Tried new drivers (twice).
    Tried to roll back drivers
    Tried installing old drivers from disk
    [sigh] nothing has been working...
    Might try one last time on the drivers tonight.
  4. But wait...it gets better! Now IE6 crashes almost every time it's opened for a few minutes AND now I get random computer restarts.
    Based on that statement alone I would think the most likely culprit is a bad power supply. 3-D Games ask alot of your video card and therefore your PS couldn't keep up, as it progresses it can't do simple functions like "Boot" your computer or run IE.
    I try and another PS before losing any more hair
  5. hmmmm...might be a good call. I have a 300w PS running these the computer with these PCI's:
    AGP Nvidia FX 5600
    PCI Sound Blaster Audigy
    PCI USB2.0
    PCI Firewire
    PCI Ethernet
    The PS might be overtaxed? :P
  6. Master of Time & Space Capmaster's Avatar
    Feb 2004
    808smokey's suggestion is a good one. Power supplies are also often mislabeled, so a "300W" supply might really be a 230W one
    Another possibility: Motherboard.
  7. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Power supplies are all-important. However I think it odd that going back to an MX440 would cause further instability than with the power-leeching GFX. Bad AGP ports usually result in funny artifacts or crazy colors happening, not often do they result in reboots unless the actual card isn't sitting in there snug (losing contact). Does your GFX card have an additional power connector? That particular engine usually requires a 250W (rated) minimum power supply.
    If you do go shopping for power supplies look at Antec True or Neo series or PC Power and Cooling:
    http://www.pcpowerandcooling.com/home.htm
    The turbo 510W from PC P&C is one of the best power supplies ever made for an ATX case *drool*
