Virtualdub can do, use Video -> Direct stream copy with DV. Can also use virtualdubs frameserver or avisynth, then you dont need to make an intermediate file. With AviSynth (the best), syntax is
AviSource("File1.avi", "File2.avi") and so on. -
i seem to find virtualdub difficult is there an easier one out there?
Virtualdub takes 20 seconds to set up:
File - Open Video file - File1.avi
File - Append AVI segment - File2.avi
Video - Direct Stream Copy
File - Save AVI
or with frameserving:
File - Append AVI - File2.avi
File - Start frame server - <specify .VDR file name>
...then open the VDR file in tmpgenc and start Encoding, no intermediate file, saves lots of time and diskspace.
There may be easier ways, but IMO virtualdub is more than easy enough
You already have TMPGEnc so why not batch encode? (File->Batch Encode.) This would save you lots of space considering joining would require you to have whatever the size of your DV files are spare to give the joined file somewhere to live.Originally Posted by efiste2
Is there a particular reason why you specifically need to join all the files first?
FLV Joiner
By Wolfin2010 in forum EditingReplies: 6Last Post: 17th Oct 2012, 19:27 -
m2ts file joiner
By triassicpark1 in forum EditingReplies: 3Last Post: 25th Jan 2012, 20:11 -
MPEG Joiner ?
By ashe09 in forum Video ConversionReplies: 12Last Post: 12th Oct 2011, 04:14 -
RM Joiner
By nic3 in forum EditingReplies: 2Last Post: 8th Sep 2009, 06:24 -
Best Video Joiner
By funnyclown11 in forum EditingReplies: 1Last Post: 4th Jul 2007, 02:29
