I'm about to get a DVD Burner and I want to know which program would be the best and easiest program for me.
What I want to do is make a DVD with a menu! I will have 10 movie files on the DVD. I want there to be 2 movies to be played before the menu appears (sort of like an introduction). Which program does that?
I'd recommend TMPGEnc DVD Author. It comes at a decent price and is fairly flexible, though there are others with more in depth options. Its a good solid package though, especially if you are looking for some simple menus or wish to create some basic custom menus.
Give the Ulead VideoStudio 8 trial version a try. It is completely functional for 30 days. It is easy to use and does a great job.
Thanks. Those two were the first ones that came to my mind. I guess I was right. I'll try them out.
dvdlab is also worth checking out. Simple to use but allows you to be pretty creative.
Simplest DVD authoring program?
By paristideu in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2011, 11:08 -
A good dvd authoring program?
By t_jay17 in forum Authoring (DVD)Replies: 3Last Post: 31st Mar 2010, 21:50 -
Which dvd authoring program could I use...
By sagat93 in forum Authoring (DVD)Replies: 5Last Post: 14th Oct 2009, 21:43 -
which dvd-authoring program is better?
By siluet in forum Authoring (DVD)Replies: 9Last Post: 8th Oct 2008, 14:25 -
The Best DVD Authoring program
By Random490 in forum Authoring (DVD)Replies: 6Last Post: 12th Dec 2007, 04:10
