  1. i want to back up 2 dvd's and put them onto the same disc.but how do i do this?is there a program that you can do this with.i use dvd shrink at the moment and that wont let me do it.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    This is a relatively new guide that might help:
    https://www.videohelp.com/guides.php?link=646
    Also, you could shrink one movie first then shrink the second. Assuming both fit on a dvd-r just author them to one disc. Good luck.
    Kevin
  3. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    http://dvdshrink.info/compilation.php
    that allows you to put 2 movies onto 1 DVD with DVDShrink
    you may need to rip one 1st if you only have 1 ripping drive
  4. cheers very much for your help.
