Is there any way to have a menu where I could put multiple mpegs, like for extra features, besides the main menu? The only way I could think of doing this would be to merge the mpegs that I wanted to have in the features menu into 1 mpeg and then import it into DVD Author. Then make the chapter marks where each feature in the merged mpeg started. So essentially the extra features menu would be the chapter menu for the merged mpeg. Is there an easier way to have another menu besides the main menu? If not, is there a good program for merging multiple mpegs, that doesn't have to rerender the files? Thanks.
Do you mean like a motion menu? You can do that in DVDAuthorGUI but you already have to have the mpegs merged. DVDAuthorGUI has a motion menu creator if you have Avisynth installed.
Hope this helps.
RogThere are many ways to measure success. You just have to find your own yardstick. -
I don't mean like a motion menu but like another main inside the main menu where I could put multiple mpegs. I attached a diagram, I hope that helps explain it.
Simply make a 2nd titleset menu, and on the first menu, include a button that jumps to menu 2.
You may also want to include a buttton on menu 2 that jumps back to menu1 -
That is exactly correct. I have done the same thing successfully and it works wonderfully.
"What? Huh?!? WHAT will come out no more?!?" Jack Burton -- BIG TROUBLE IN LITTLE CHINA
In GUI Dvd Author-my finished dvd has no sound on the menu in some players?
By extent in forum Authoring (DVD)Replies: 3Last Post: 2nd May 2009, 05:19 -
GUI for DVD Author (GFD) 'Freezes'
By olyteddy in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 13:09 -
question about how to omit title menu using GUI For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 14th Dec 2007, 10:34 -
GUI For DVD Author - A Couple of Questions
By deadwing in forum Authoring (DVD)Replies: 8Last Post: 6th Sep 2007, 02:25 -
DVD Author Gui
By Flying Doctor in forum Authoring (DVD)Replies: 4Last Post: 1st Aug 2007, 09:12
