You can also set the amount of hard drive space used for the recycle bin or you could disable the recycle bin altogether and free up space.
Results 31 to 34 of 34
Not to hijack but, what's the minimum amount of RAM you recommend to run 2K or Xp without a swap file altogether?
Nothing can stop me now, 'cause I don't care anymore. -
I wouldn't recommend that. You could be in for some bizarre memory errors if you get close to running out. Windows has been designed to use a swapfile since the early days of Windows runtime 2. At least leave a little there for it to use because without one ...who knows?Originally Posted by ViRaL1
OK guys, everything is fine now.
The CLISD thing had to do with bad drivers *I think.*
encodings troubles
By Benjy in forum Blu-ray RippingReplies: 9Last Post: 23rd Oct 2009, 00:22 -
Subtitle troubles
By ROOK1E in forum SubtitleReplies: 1Last Post: 1st Aug 2008, 03:48 -
ipod troubles...again!
By SE14man in forum Newbie / General discussionsReplies: 11Last Post: 12th Nov 2007, 20:52 -
TV Out Troubles.
By SE14man in forum Newbie / General discussionsReplies: 54Last Post: 11th Oct 2007, 16:55 -
Terrible PC troubles..
By SE14man in forum Newbie / General discussionsReplies: 9Last Post: 29th Sep 2007, 14:04
