I have some mpeg2 files that I would like to take a still frame shot out of it and use it as a photo or background. Is there any way I can take just one frame and make it into a file? I would like to put it into iphoto if that makes a difference. iphoto not a must though.
Repeat after me:
1. Open the mpeg-2 (.m2v) in Quicktime Pro.
Find the part you want to make a still of...
2. Scale your QT window as big as possible,
or at least relative to the size you will
be making it a background.
3. go to versiontracker.com and get Capture Me!
4. Install and launch Capture Me!.
5. Place the window of Capture Me! Over the QT Window,
sizing to get all of your picture.
5. Click once in it to "capture".
6. From the Menu, select save,
save as .tiff, best quality.
Repeat as often as necessary.....
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 13:24 -
16:9 shot, but 4:3 in DVD Architect.
By zovx in forum Authoring (DVD)Replies: 25Last Post: 14th Oct 2010, 09:46 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
automatic shot by shot video cutter
By monks19 in forum EditingReplies: 4Last Post: 26th Oct 2009, 20:17 -
What shot is this called?
By Chippy in forum Newbie / General discussionsReplies: 4Last Post: 18th Apr 2009, 00:47
