I have four [.m2v] & [.mp2] files that I wanted to burn to DVD. I used TMPGEnc to encode, but TMPGEnc did not extract the audio properly from the [.avi]'s. I forgot to check this before encoding and just went on with the whole process, burning video with no proper audio (there was no sound). When I realized this, I took the [.vob] files I had and then tried splitting, demuxing, remuxing, etc using various programs. I finally got four working [.m2v]'s & four working [.mp2]'s. For the [.mp2]'s, I just used VirtualDub to extract the [.wav]'s from the original [.avi]'s and encoded to [.mp2] with 2Lame.
DVDAuthorGui accepted (recognized as valid mpeg audio files), of course, all of the [.mp2] files, but it only accpted the first and the fourth [.m2v] files, not the second and third [.m2v] files. It said something like "unrecognizable file." My guess is that somewhere in the demuxing, splitting, merging, remuxing, etc., the [.m2v] files got the wrong streams. Is there a program that I can use to give those two [.m2v]'s valid Mpeg2 headers? I tried muxing with TMPGEnc, but it won't open the [.m2v] files. It says "Invalid Mpeg Stream." The videos play fine in WMPlayer though.
you could try something like dvdpatcher. copy the settings from the first working m2v. but I would instead demultiplex the vob again.
-I tried DVDPatcher; I think it's only good for taking out of spec MPEG2's and patching them to DVD specs so that authoring programs will accept them.
-As far as the original [.vob]'s, I already deleted them and threw away the DVD. This time, I'll just have to reencode. I don't need it for this time, but is there any program that can change the stream id (or maybe add a stream id, I really don't know what else to call it)? For example, the thing that identifies an [.m2v] as SVCD or DVD. When I tried to use TMPGEnc's "Mpeg Tools" to multiplex that [.m2v] with "Mpeg2 (Program VBR)" header - what you use for DVD [.m2v]'s - it wouldn't even open the file.
-Well, anyways, thanks.
DVDAuthorGUI Problem...
By beckmen in forum Authoring (DVD)Replies: 12Last Post: 1st Jul 2010, 13:34 -
Blu-ray disk authoring: BD player rejects them
By swraman in forum Authoring (Blu-ray)Replies: 16Last Post: 26th Sep 2009, 08:39 -
DVDAuthorGUI: How do I write?
By videohalp in forum Authoring (DVD)Replies: 1Last Post: 8th Jul 2008, 21:29 -
DVDauthorGUI question
By AlecWest in forum Authoring (DVD)Replies: 2Last Post: 20th May 2008, 13:46 -
DVDauthorGUI gifMasks transparency?
By chewie8008 in forum Authoring (DVD)Replies: 10Last Post: 19th Jul 2007, 14:31
