I have a nec2500 a using dangerous brother 1.07 firmware patch.
I usually rip with DVD Decrypter or DVD Shrink depending what mood I am in. However I did find problems with the NERO plug in. Whereby if you create an image the way it writes it to disk makes my hardware player search a lot for its data (no degridation just annoying noise !). To any new Authoring people I would fully recommend outputting to a video TS folder and then going into nero, selecting create DVD video then manually dropping the files in. By using this method I have found hardware players do not appear to go mad when reading the disks !!! I have also noticed that Bulkpaq disks can sometime freeze near the end of films or start going blocky. I try not to use these now. But if anyone has a shit load of Bulkpaqs they need to use I reccomend in DVD shrink dropdown the disk size from auto (4.7 GB) to custom and set it to say 4300. Then they seem to play alright.
If you are burning stuff for yourself I'd always go for Intenso -R x 4. Yes they will cost you 60p, but at least you can read them at a later stage. The 2500 is not the best of readers !!! Does anybody else have any handy hints for newbie and oldie users ? Oh yes if any of you copy copies then I would still run them through decrypter as its a lot qiuicker than cut and paste !
Results 1 to 1 of 1
What happened to the orange cone? Vertical Lines in deep reds and oranges.
By Sullah in forum Video ConversionReplies: 12Last Post: 24th Jul 2011, 17:01 -
anyone know how to unlock denon dvd-2500 regions
By similar in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2011, 15:03 -
I just bought an expensive laptop - was it a $2500 mistake?
By Eat Right in forum ComputerReplies: 35Last Post: 18th Nov 2009, 13:33 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 12:34 -
DVD shrink is only encoding @ 2500 KB/s or so? Instead of the 12000KB/s?
By Denvers Dawgs in forum DVD RippingReplies: 6Last Post: 29th Jun 2008, 11:23
