I ripped a dvd and received the vob files for it.I read several articles about converting the vob files to a mpeg format.As i am quite new at this video stuff i do not understand what i need to do.
I've got vobedit,now when i want to use it to convert to mpeg it gives me all the vob files from the dvd.Which of these files do i use to convert?
I would appreciate all help or tutorials that will explain this for me.
Results 1 to 9 of 9
What are you trying to create as your final product? Just mpegs or a DVD or VCD?
"Art is making something out of nothing and selling it." - Frank Zappa -
Hello,
For dvd to mpg try this:
https://www.videohelp.com/guides.php?link=638
Hope this helps.
VOB files are MPEG files already. Sometimes a quick and dirty method is to simply rename the file with ".mpg" instead of ".vob". It doesn't always work with all editors though.
My technique:
- Rip DVD
- Run DvdShrink to extract just the movie or clip that I want. Also, remove unwanted audio streams.
- Get a command window (like a dos prompt window but not really) and cd to the output directory of DvdShrink.
- If there is just one file VTS_01_0.VOB just rename it to MyVid.mpg.
- If there are multiple VTS_01_?.VOB files type the command:
COPY /B VTS_01_0.VOB VTS_01_1.VOB (list remaining vob files here) MyVid.mpg
This will join all the files together to create the final file.
Sometimes, just a simple rename of a VOB file will work but many times a single VOB file can contain many short videos/advertisements and contain many audio tracks such that it is just useless. The DvdShrink method will make sure you get what you want. It also allows you to select a range of the video to save.Ted Rossin
http://www.tedrossin.0sites.net/ -
Just demux the VOB files to elementary streams. You'll get the MPEG2 and associated audio files.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 07:31 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting .mpg-files to .vob-files ?
By stuckinsnow in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 09:11 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
