hey guys,
got a question for you, premiere gurus,
I have a clip of an girl holding a photograph, (and in this anime series, her looking at this photograph sparks a memory) and I want to use a filter that will let me do a zoom effect to make it look like one is going into the photograph, and have the photograph fadeout while zooming in and have the next clip start (the memory).
is this possible?
if so, what filter do I use?
thanks for any help,
sincerely,
schunn99,
preimere newbie.
You can put the clip of "the girl with the picture" on track 2. Put the next clip on track 1. You can set it up so that the end of the top clip overlaps the start of the bottom clip by about 3 sec or so.
Select the top clip and go into the effects pallet. Select Scale and set it to zoom into the photograph about 4 sec before the end.
Next: Select Opacity set keframe 1 sec before end @ 100%, then end keframe @ 0%.
That should give the effect you want.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
or you could put a cross-dissolve transition in the transitions track in the spot where the clips overlap. instead of fading out.
Question about Premiere Pro's aspect ratio math
By Asterra in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2011, 08:15 -
Simple Question re Premiere CS5
By jkholmes in forum Newbie / General discussionsReplies: 10Last Post: 3rd Mar 2011, 21:50 -
premiere pro rendering question
By thecrock in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2009, 16:30 -
MP4Cam2AVI to Adobe Premiere Question
By jwfc in forum EditingReplies: 3Last Post: 16th Nov 2008, 14:52 -
final cut pro - advanced question
By marinebc11 in forum MacReplies: 2Last Post: 18th Aug 2008, 10:01
