Results 1 to 13 of 13
  1. Hi to all, Have been reading these forums for a while but this is my first post!
    I've only just got a G5 Dual 1.8 and it rocks!
    Some Questions I have are
    1) What is the Longest Part of the DVD copying process?
    I've alreday used DVDbackup and it doesn't take much time (a couple of hours at most to rip a DVD to my HD
    2) I've been told that you can shrink any sized DVD when using DVD2ONEX is this true and what side affects are there for having a big DVD ie >6GB?
    3) I've read that many people use different apps like MTR or DVD backup if I want to copy the whole DVD what app should I be using?
    4) Might link in to the above question but why if you can don't people copy all the features on a DVD?
    Thanks for any help!
    "Something Funny"
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    I'm a pc user so I can't help on the other questions. But, people sometimes skip the extras for quality reasonse. The less you have to compress the better the main movie will look. If you remove up to a 1/3 or more of the main disc (extras take up space) than you can concentrate on increasing the quality of the movie.
    Kevin
    P.S. Sometimes it's not noticeable if there are few features but some just want to pop in the disc and autoplay (why waste time with fancy menus and features if you don't want them?)
  3. Thanks for the info Yoda, anyone else with any answers?
    "Something Funny"
    Jun 2001
    Silver Spring, MD USA
    For me, the longest part is the DVD2OneX step. I have an older PowerBook with a 667MHz G4 so its the processor thats the bottleneck. It also used to take me an hour to burn a full DVD but I upgraded to an 8x burner recently so it takes six minutes now.
    I use MacTheRipper and YadeX. MTR is great for whole disc ripping, as it is exceptionally fast, even on my slow laptop. MTR has other functionality (ripping by title set, by chapter) and they work fine. I use YadeX for ripping by chapter or title set because I can get down to the cell level, if I want, and maintain audio sync. Go with the ripper that feels more intuitive to you, but by all means, give up DVDBackup. It's old and slow and probably no longer being updated (the developer had some serious issues with the developers of DVD2OneX -- long story).
    I tend to not copy the extra features on a DVD because sometimes they are boring or crappy, or their value is gone after one viewing. I buy DVDs for the movie itself, not to see highly compensated actors flub their lines repeatedly. If I find some extras worth keeping, I'll actually make an SVCD of them.
  5. AntnyMD you say you rip a DVD (ie copy iot to your HD) in 6 mins unsing DVD2oneX? I'm going to stop using DVDBack up then!
    "Something Funny"
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    DVD2OneX isn't a ripper, it's only an encoder. DVDBackup is now old and outdated, try using MacTheRipper or yadeX, like AntnyMD suggested. Both of those a more current rippers and better handle DVDs.
    Jun 2001
    No.
    It takes me about six minutes (and change) to BURN an 8x DVD-R.
  8. What media do you use?
    I'm thinking about buying some DVD-R but only about 10 or so I don't want to buy a huge amount and then find out they're crap
    "Something Funny"
    Jun 2001
    The 8x media I've used is Verbatim. I am still a user of 2x TDK media since I can get it for $1 per disc in bulk. I use Apple 4x media from time to time, but at 2 dollars a pop, I use Apple only when in a pinch and need media right away.
    May 2004
    Ann Arbor, MI
    I have a G5 2.0 dualie with 1 GB RAM...and it rocks! I got one of the first ones shipped last October and it has been problem free out of the box.
    I run MTR2 for the ripping and it takes ~ 10 minutes or less for an extraction. I usually don't save the xtras for the reasons cited by others.
    Compression via DVD2OneX takes ~ 4-6 minutes and burning via Toast 6 takes about 15-20 minutes depending on the media.
    Verbatim (movie reel) has been hit and miss...about 1/3 coasters. Memorex about the same. Apple-branded have been perfect. I just bought some printable ones from Shop4Tech in bulk but have not burned enough of them for a valid evaluation.
    I have imported some stuff via Tivo into iMovie then burned using iDVD or Toast. If you use the iLife package make sure you've updated to 10.3.5 first, then update the iLife modules.
    Merlin Macuser
    Ann Arbor, MI
  11. Originally Posted by AntnyMD
    where do you get your 2x TDK from if I may ask...I've been trying to find a good place to get some, as I only have 2x burner(a04)
    Friends don't let friends use Windows!
    Elisha Cuthbert is so a total schorchcake!!
    Jun 2001
    I go back and forth between Staples, and J&R Music World.
  13. Member twosocks's Avatar
    Jul 2003
    Right Here.....
    Best Buy will sell the spindles of 25 for as low as $25.00, about every 4 to 6 weeks.
    I've also had great success with the Movie Reel Verbatim's, which Best Buy has also sells, periodically, for less than $25.00 for a spindle of 25.
    I've burned approximately 75 with only 1 bad one and that one was my mistake.[/b]
