I've got a question: when i transfer a video from a Mini-DV-cam to my computer, in which format will it be saved? In a tutorial i read that the output-format is .avi but that would be veeeery big, wouldnt it? Is there any way to save it compressed on my hard disk without saving it uncompressed first?
dv avi is 13 GB/ hour, 216 MB/minute. some encoders can compress directly to dvd mpeg like mainconcept mpeg encoder.
An avi file is a container. It can contain various types of compressed video and uncompressed video.Originally Posted by FinalFn
DV is a fixed 5:1 compression stored in an avi file.
MPEG is a variable compression that allows a better ratio than DV. MPEG1 & 2 are generally stored in an mpg file.
Video is very big. If you think your DV is big, uncompressed is 5 times bigger. It is good to have a large hard drive. Well worth it at todays prices.
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44 -
Reduce file size vs. compression question. Am I doing this right?
By Ronny G in forum Authoring (DVD)Replies: 9Last Post: 29th Dec 2008, 09:30 -
Question about burning file size
By magikero01 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jan 2008, 08:34 -
FLV File size question
By YoKnows in forum Video ConversionReplies: 3Last Post: 14th Jun 2007, 15:44 -
Captured File Size Question
By pbmc59 in forum Capturing and VCRReplies: 10Last Post: 6th May 2007, 21:41
