first off, i use winiso to make the iso image file with just the avi file on it
i use alcohol 120% to burn the image to a cd
when i try to load the cd and copy the image file using alcohol 120%, i usually get an error saying "the file did not finish, do you want to delete the image?" am i burning these right? cuz i have burned over 200 movies onto cd using this method
or
i am doing this right, just the cd gets sracted easily?
what is the best way to burn avi files to cd?
----> adamf9898 ---->
I burn it as a data CD with Nero and I have never had any problems.Originally Posted by adamf9898
i guess its just the crappy cdr discs, they get scratched too easilty
----> adamf9898 ----> -
Agree with just burning them as a data disc.
Try burning them at a slower speed, but likely if it isn't a buffer underrun then it is probably up to cheap discs.
-Suntan -
ok thanks for the advice
i usually burn at max speed, so what speed do you recommend? also, y would the recording speed change anything?----> adamf9898 ---->
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
odd message from Toast while burning DIVX/XVID
By muttonhead in forum MacReplies: 6Last Post: 11th Sep 2008, 18:23 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 18:16 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
