Hi everyone,
I've used Movie Mill to capture my vhs home movies and now I'm looking for the best/easiest software to record them on DVD. My HP currently has MYDVD which no longer operates after the trial period and I'm looking to buy something. thanks
If the files are DVD compliant, all you need to do is author and burn them. I would use TMPGEnc DVD Author. It's fairly easy to use, popular, and has a trial version.
TMPGEnc DVD Author is excellent and easy. Popular also as you can see above.
Dvdauthor 0.6 with DVDauthor GUI is free.
Just some options. -
For free I would recommend DVD Author GUI. Its easier than it looks at first to make a dvd. What you need to do is read the html file that comes with it. I t has pretty detailed instructions on how to create a dvd. You may or may not know this but (when you are ready to create your dvd) it makes two folders called VIDEO_TS and AUDIO_TS. These contain your files for your dvd. Then just take your favorite burning software, create a data dvd, and drop these two folders on them. This software is good quality for being free.
Software Advice Wanted
By CthulhuSaves in forum DVD RippingReplies: 3Last Post: 16th Feb 2011, 14:25 -
Software advice please
By mauiwowi in forum Capturing and VCRReplies: 1Last Post: 15th May 2009, 11:54 -
editing software advice
By tommcd64 in forum EditingReplies: 4Last Post: 27th Oct 2007, 20:44 -
Advice on editing software
By Newbie 332 in forum EditingReplies: 8Last Post: 25th Jul 2007, 09:57 -
Software Advice
By asdfasdf in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2007, 12:27
