I have two computers with essentially the same hardware and software (some minor differences).
Until about 2 weeks ago I had no problems burning DVDs using Ritek, Ridata and TY blanks. All of a sudden, on one of the computers I started getting a lot of spikes when checking Ritek and Ridata disks burned on one of the computers with KProbe. At first I thought it might be a bad batch of disks, so I mixed several disk from the same box between the two computers- the same computer still gave me a lot (60-80%) of bad burns. Meanwhile, the TY disks still burned fine on both computers.
I tried switching DVD burners between the two computers and the problem didn't follow the burner- it stayed on the same computer. Then I tried switching cables, memory chips, ATA controller cards between the computers. I switched just about everything except the motherboard and the processor between the two computers and the same computer kept giving bad burns no matter what hardware was switched.
I finally gave up and started using only TY disks on that computer- until yesterday. Now I'm starting to get bad burns on the TYs.
As far as I can tell there's some kind of problem with either the motherboard or the processor that's causing burn problems, but I don't know what kind of problem would cause bad DVD burns without causing other problems on that computer.
My next step is get try and borrow a different motherboard (and/or processor) and put them in the problem computer, but before I do that is there anything else I can do to try and narrow down where the problem is?
You could try a utility like SiSandra. Heres one version of it: http://www.overclockersclub.com/downloadcenter/download.php?action=file&id=12.
It would let you test components of the systems. It may be the motherboard, or something in the software. -
I'll try SiSandra.
I know it's not the software or Windows- At one point I did a clean install of Windows and then installed just the burn program to test that. -
The fact that it would only burn TY and then started spitting those out sure sounds like an optics package that's taking a dump...Originally Posted by BobK
Power supply power supply power supply, that's a common culprit.
Mother board is also still a good possibility. With millions of internal components and a multitude of interactions there's no reasonable way to know until you swap it out. Even if you had the test equipment it's simply faster to swap for locating problems like this. Hard drives too, even with a reinstall one could be flaky.
Alan -
Gee alan, do you think it is the power supply?Originally Posted by Alan69
:P
:P
Thanks for the suggestions. SiSandra didn't show any problems, so it looks like I have to track down a motherboard and try swapping it out. If that doesn't work I get a different power supply to try.
And if none of that works I guess I'll get a new computer.
Burn Errors due to MPGV ?
By mrlewp in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2010, 19:54 -
Encoding errors, cannot burn DVD
By Surber in forum Authoring (DVD)Replies: 3Last Post: 8th Apr 2010, 11:55 -
Downloading Motherboard Upgrades to my Motherboard
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2009, 15:54 -
SVCD2DVD causing Timecode Errors??
By denmc in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 15th Feb 2008, 16:59 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 03:22
