  1. I've successfully encoded using MPEG4 or XVID with the mencoder engine.
    But if I try the ffmpeg engine on the same source the encoding starts then finishes instantly. If I click on information it says
    Encoding started on ...
    /Volumes/Main/Ready/movie one/VIDEO_TS: Unknown format
    Any tips?
    Is the mencoder engine better for archiving DVDs of tv episodes anyway?
    Cheers,
    B
  2. ffmpeg engine does not support VIDEO_TS input. Use VOB with it.
  3. Hmmm. So if you have a VIDEO_TS folder with a few vobs, and one episode is spread over 1+ vob, does ffmpeg work or do you need one vob file?
    Maybe I should stick with mencoder.
    B
  4. Master of my domain thoughton's Avatar
    England
    You would normally rip it as a single VOB (don't rip the complete disc) and then process that. MTR and 0sex (and I think yadeX too) can do this.
    Tim Houghton
    WebsitePhotography
  5. Originally Posted by major
    Can we expect this in a further update?
