Ok, thanks to FulciLives and the help of others, I have the following Synth Script for my DV/Analog files. I just load this to CCE and convert.
PROBLEM: The end result is still 720x480 but the image is 352x480. You guessed it, the rest of the 720x480 resolution is filled with black masking. How do I get rid of this so that the end result is full 4:3 352x480 with no masking?
LoadPlugin("Convolution3d.dll")
LoadPlugin("Reinterpolate411.dll")
avisource("C:\Movie Conversion\capture0001.avi")
ConverttoYUY2(interlaced=true)
ReInterpolate411()
Trim(x,y) // Do Not Add This Line Until After Loading in VirtualDubMod
crop(8,4,-8,-12)
SeparateFields()
odd=SelectOdd.Convolution3D (0, 32, 128, 16, 64, 10, 0)
evn=SelectEven.Convolution3D (0, 32, 128, 16, 64, 10, 0)
Interleave(evn,odd)
Weave()
DoubleWeave.SelectOdd()
AddBorders(8,8,8,8 ) // To avoid smiley, space added here 8 )
LanczosResize(352,480)
Results 1 to 11 of 11
This is what I thought, but I never really paid close attention to CCE and resolution options because I didn't think the user could set the resolution with CCE. I guess I was wrong. I will take a closer look at the resolution options in CCE.
Thanks again. -
Something is wrong here. It seems to me that you are going directly from 720x480 to 352x480. The right way to do it (to end up with the correct pixel aspect ratio) is to crop 720x480 into 704x480, then to resize the result (using Lanczsos, or whatever) to 352x480.
I have the impression that many people are confused over the 720 vs. 704 issue. This confusion is encouraged by a handful of encoder templates or presets that contain 720 and 352, but not 704. TMPGEnc is notorious: you have to unlock the size setting to go from 720 to 704 (if 704 is what you want), and you have to explicitly clip the frame by 8 pixels, if you want to go from 720 (e.g. DV source) to either 704 or 352. Clueless users will end up with incorrect pixel aspect ratios. Grrrr.....
Best regardsCosmin -
crop(8,4,-8,-12)
Isn't the crop script essentially doing this? Converting from 720 to 704 and then using Lanzcos to resize to 352. -
Maybe you have the dvd compliant option checked in CCE?
This will resize all 29.97fps material to 720x480 regardless of its source resolution.
As illogical as it seems, if you are encoding for DVD then you should actually uncheck the dvd compliant option, for various reasons. -
Ok...
If my source is 720x480, I use...
crop(8,2,-8,-14)
addborders(0,8,0,8 )
If my source is 640x480, I use...
crop(0,2,0,-14)
addborders(32,8,32,8 )
This will give me a 704x480 resolution before Lanczos(352,480) resizing.
In CCE, I do not check DVD COMPLIANT if I want to maintain the 352x480 resolution defined in script: Lanczos(352,480).
Thanks bugster, cosmin, and adam! -
This is good. In the initial message, you hadOriginally Posted by LNielsen76
addborders( 8, 8, 8, 8 )
and that would give you 720x480.
I didn't know about this. Thanks for the tip. I wonder why are so many MPEG encoders so stubborn into 720x480.Originally Posted by adamCosmin -
In my opinion, you should never use the dvd compliant option in CCE for anything. What it does is, resizes to the appropriate full D1 resolution and tag the nominal bitrate flag at 9.8Mbits, which of course is fully compliant but it can cause problems in many dvd authoring programs if 9.8 + audio bitrate exceeds the 10.08 limit...even though the actual bitrate is well under that limit.
Just make sure that you are feeding CCE with a compliant resolution and that you encode with dvd compliant settings (bitrate and GOP settings,) and the dvd compliant option is unneccesary. -
I have noticed this loading my resulting files in TMPGEnc DVD Author! However, this isn't the case in DVDlab.What it does is, resizes to the appropriate full D1 resolution and tag the nominal bitrate flag at 9.8Mbits, which of course is fully compliant but it can cause problems in many dvd authoring programs if 9.8 + audio bitrate exceeds the 10.08 limit...even though the actual bitrate is well under that limit.
Yet another great tip!
Converting 720x480 to 352x480
By Regor21 in forum Video ConversionReplies: 8Last Post: 9th Mar 2011, 10:34 -
Bitrate 720x480 vs 352x480 concept question
By CaZeek in forum Capturing and VCRReplies: 15Last Post: 8th Oct 2010, 12:08 -
Higher resolution sizes than 720x480 on MeGUI?
By Umandsf in forum Video ConversionReplies: 2Last Post: 4th Apr 2010, 07:10 -
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 13:43 -
720x480 or 352x480 ?
By StoneColdWhat in forum Video ConversionReplies: 7Last Post: 7th Aug 2009, 08:16
