Right, first off i'm sorry if this subject matter has already been covered, i searched the forum, and found nothing.
Basically, i want to burn 3 svcds to a single dvd-r. I've downloaded "a film" which is in 3 files, (bin/cue) what i want to achive, is to be able to burn all three of these bin. files to a single dvd-r, rather than 3 cds. So that i'm able to pop my dvd-r in my standalone dvd player, and watch my movie.
Any ideas would be great![]()
Results 1 to 10 of 10
I typed ' svcd to dvd ' in the search field, this is what came up:
Too many hits (12978). Try again and specify your search better, add more keywords or google search for svcd to dvd in our forum here. -
Hello,
What Faithful Follower meant was that you should have READ one of those thousands of hits first. However, here is a place to start:
https://www.videohelp.com/convert
That should narrow it down for you.
use gooogle search!!!"!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.google.com/search?domains=www.videohelp.com&sitesearch=www.videohelp.com&sa...SVCD+to+DVD%22 -
Hello,
If that's aimed at me that's a low blowBaldrick -use gooogle search!!!"!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.google.com/search?domains=ww ... +to+DVD%22
Kevin
P.S. I said I was sorry, I just thought a large button for newbies might slow down obvious questions.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
jesus, he's just asking a question.....
if you need about 3-4hrs you should encode it at half D1 360x240 and 3500 bitrate....
BUT, better go to TOOLS and get a bitrate calculator and decide what you want.
the ideea is, that don't go lower than a 3000 bitrate for a full 720x480 resolution, you better lower the resolution and keep as high as you can the bitrate....got it ? -
i'm talking to the users that used the forum search.Originally Posted by yoda313
easiest www.svcd2dvd.com but not fully compliant. -
Hello,
I'm sorry, I guess I was taking the hits too literally in that other thread. I need to lighten up a little, I guess. Have a nice day.Baldrick - i'm talking to the users that used the forum search.
You could also simply extract the mpg files from the bin\cue files with VCDGear and read this guide https://www.videohelp.com/svcddvdr.htm for more information about what to do...
You should also check if your dvdplayer supports dvd's with svcd... (look under DVD Players in the menu <- )10110101100111012011 <- The bug Bill doesn't talk about.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
n00b saving in Ulead for svcds and dvds myspace
By dsound in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2008, 13:40 -
2.5.3300 SVCDs getting recoded
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 15th Oct 2007, 22:44 -
Winavi v8 SVCDs jerking with SVCD2DVD
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 13th Jun 2007, 17:02
