i have one big mp3 file right, its an album, but the songs are all joined together, i wanna know what software i can use to split the file in the specific places...can anyone recomend what to use and how to use it...
Results 1 to 12 of 12
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Hello,
Let's see, there's:
Cakewalk Pyro,
Goldwave,
Audacity,
And that's just to name a few!
Check out this part of this website:
https://www.videohelp.com/tools
There's plenty there, just look up the audio section.
tru, i use goldwave alot...but i ddn't know it had that function, where can i find that function ,and what should i do...holla back or send me alink to finnd out how to split the file....
I use sonic foundry soundforge ... just open the mp3 file cut the first song ... select the edit tab ... select paste special ... then paste to new..... then goto the file tab and select save as .... repeat for each song ... job done.
Hello,
Well, I could be wrong. I just hear that mentioned a lot here. I personally use Cakewalk Pyro 2003 for my mp3 editing. Somebody here should be able to clarify it for you.SIRCOOKS-tru, i use goldwave alot...but i ddn't know it had that function,
Kevin
EDIT -- You already have another suggestion - soundforge, thanks psx_pirate!Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
do u find it much easier using the cakewalk software....
Hello,
Personally, yes. But it is payware ($50US I think, could be wrong). But I'm sure most software is essentially the same.
It let's you see the soundwave and zoom in to get the precise second you want to trim. It only does mp3, wav, wma so if your into others like aac or ogm you may want to keep looking.
The instructions given for Sonic soundforge should work ALMOST identically for goldwave.
thanks
Creating M4B files from MP3, then splitting
By hungledink in forum AudioReplies: 1Last Post: 12th May 2009, 16:54 -
Splitting long (hours) MP3 files by sound breaks
By lostinlodos in forum AudioReplies: 3Last Post: 19th Mar 2009, 22:37 -
Cutting/Splitting an MP3 Audio with MP3Direct Cut
By UmmAddan in forum AudioReplies: 2Last Post: 22nd Jan 2008, 19:03 -
Suggestions for splitting MP3 into 10min chunks?
By j_hallgren in forum AudioReplies: 3Last Post: 7th Jan 2008, 22:36
