  1. Yes, and it sucks...
    Some of the movies i would like to encode to MPEG from AVI.
    I use TMPGEnc-2.01.30.116 and when push the button Start it says >>> An error occured when audio was decoded, then i say - What the f*ck =)
    I have alot of movies now that i cant encode and i dont think im lonely of this shity problem...SO, i would be wery glad if someone can help me with this !!!
    Many Regards // Johan - Sweden
  2. Try extracting the audio in virtualdub, then converting this to PCM uncompressed. Use this as your source.
  3. I had the same problem, solution I used? raise your directshow to priority 1 under options-enviromental settings-vfapi plugin. I found 1(+) to be best since anything higher made encoding slower and divx playback wasnt working correctly (artifacting bad)
