Hi,
I've looked all over this forum, and Google. Can't find mzlmerger. What is it? Where do I find it.
Thanks,
Mike
Results 31 to 36 of 36
Just pm me with your email address and I'll be glad to send it to you! I have a bunch of other programs written to work with the DVC 150's app DVXCEL.exe. Check and see if you have it (default directory is C:\program files\Dazzle Multimedia\Digital Video Creator 150\). One, called dtool2 will let you set capture times. Moviestar 5 is really no good and this way you can capture with the card and use a pretty good app.Hi,
Thanks,
Mike
Garibaldi -
Try this site:
http://www.geocities.com/TimesSquare/Ring/9777/tvviewer.html
It has a program that works with my Dazzle DVC 80. However it doesn't support the audio (apparently) and it doesn't capture, it only shows what's coming through the card. -
If you have the DVXCEL.exe capture program I can send you a whole bunch of apps that will let you capture with timers, without splitting, and many other features!
I lost my installation CD and got the pure drivers from a driver site. I don't like MovieStar anyway so I figured I didn't need it.
Sabrent Video DVD Maker Video Capture Creator Anyone?
By Rayj00 in forum Capturing and VCRReplies: 3Last Post: 16th Aug 2011, 11:10 -
Dazzle Video Creator Plus Help Please!
By FragpooL in forum Capturing and VCRReplies: 1Last Post: 24th Jun 2011, 00:51 -
Dazzle Vid Creator Plus, or TV tuner card?
By cwb in forum Capturing and VCRReplies: 3Last Post: 21st Jul 2009, 09:38 -
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 17:08 -
Capture with Dazzle DVC170 with another program?
By Glaucous in forum Capturing and VCRReplies: 0Last Post: 19th Jul 2007, 09:53
