I have found this on the ffmpeg webpage but I still don't understand it....
"The quantizer is the compression level used to encode a frame. More compression means smaller filesize and less image quality. Complex frames will require more compression in order to fit in a constant bitrate, so the quantizer will vary within the qmin/qmax range in attempt to control the bitrate. Range is 1-31, though qmin=1 is not recommended. Setting qmin=qmax will lead to variable bitrate encoding."
So in what direction do I have to set the Qmin and Qmax to get better quality. How do I obtain a constant bitrate using ffmpeg engine for encoding to Mpeg 2?
AVStoDVD - Quantizer..?
By VenusAndMars in forum Authoring (DVD)Replies: 16Last Post: 15th Jun 2012, 08:59 -
Is DivX Quantizer 1 Loseless?
By Anakin in forum Video ConversionReplies: 6Last Post: 15th May 2009, 23:01 -
Is There Much Difference Between Quantizer 1 And 2 In Divx?
By Anakin in forum Video ConversionReplies: 8Last Post: 17th Apr 2009, 16:12 -
Xvid Quantizer Codecs
By theninger in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 11:54 -
Quantizer in Alltoavi
By drstew in forum Portable VideoReplies: 1Last Post: 30th Mar 2008, 15:34
