Results 1 to 9 of 9
    Jun 2004
    Detroit, MI (USA)
    i am currently mixing and producing my friends band's CD... is there a labeling type or hardware or wahtever out there so i could use to make it where all ya can see on the CD itself is text... kinda of like like photo here
    if anyone knows how i can produce that.. let me know.. basically kind of lkike the old CD's in the 80's before they got really into designing the actual CD..
    thanks
  2. Member adam's Avatar
    Sep 2000
    Well that is easily done with any cd/dvd printer. The cheaper printers either print monochrome or give you an option of usually 3 colors. They print that right on the disk.
    If you don't want to buy a hardware printer for this then just use clear labels. Just about any online vendor that sells media and labels carries these.
  3. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    I would also not use the white printable media. The Silver media looks awesome if your doing just text.
    Oct 2002
    Bodyslide says
    I have only seen white inkjet printable, who makes a silver inkjet printable? Would like to check them out.
  5. You could use one of the other disk labeling systems that just allow printing of one colour.
    The likes of staples usually sell them. Advantage is they will print onto any disk not just printable one.
    Cant for the life of me think of one of the brand names though.....
    Not bothered by small problems...
    Spend a night alone with a mosquito
  6. Originally Posted by dmagic1
    Thats the one...
  7. I've got a Casio but I wouldn't recommend it for mimicking full-face pit art, as per your example. If you have one you will soon find it's a bitch to use.
    You're better off going the clear label route or using silver printable discs. Silver printables have a trippy iridescent surface that looks pretty cool with text or monochrome designs. Depending on how many CD-Rs you plan on putting out, the Casio printer consumables can add up quickly.
    An inkjet printer that does CD/DVD would be a better investment IMO.
    Jun 2004
    Detroit, MI (USA)
    Thanks for all your replies... i j ust now got my first notification reply sent to me.. dunno why i didnt get any others.. but i will look into this some more.. t hanks again
    Shawn
