I just bought an mp3player (iriver) and when loading it, it says I don't have a HI-SPEED USB port(2.0). I want to add one to my computer, but have no idea what I need or how?
Also, what are the difference between these:
http://www.usb-2-0.com/2000300.html
http://www.usb-2-0.com/adaptec-1913500.html
http://www.usb-2-0.com/adaptec-1935400.html
http://www.usb-2-0.com/d-link-du-520.html
Which one would I need? I have no idea? Thanx for any responses
Results 1 to 14 of 14
What We Do In Life, Echoes In Eternity....
I just bought one at Fry's
I got the PPA 5 port USB2 and 3 port firewire card for $22.99
It has the VIA chipset. (I heard there were problems with the ALI chipset)
Fry's also had a USB2 only card for $11.99 on sale this week. I think it had the NEC chipset, but I'm no positive. I wanted a card that had both USB and firewire because I knew this was my last PCI slot
I wouldn't get any of those cards, because they are name brands and you have to pay extra for name brands especially Adaptec. I would go with the least expensive card I could find with a VIA or NEC chipset.
If you want a 5 port USB2 only card, this one has a NEC chipset and it's about 1/3rd the price of the ones you link to
http://www.newegg.com/app/ViewProductDesc.asp?description=15-104-216&depa=0 -
That's a bit confusing since some of those Adaptec products are discontinued. In the end any of them should be fine, Adaptec is good stuff. Do you have FireWire on your PC yet? My favorite cards are the Adaptec Duos:
http://www.newegg.com/app/ViewProductDesc.asp?description=15-152-003&depa=0
$65 for both USB2.0 and FireWire400. I've got one of these in my AMD machine and have never had problems with it and at one point that PC had all 6 PCI slots occupied. -
Now that you mention it, I don't have a fireWire on this pc. So I guess I should look for a card with USB2.0 and Firewire....So all I'll need is a card? What the hell are those adaptek kits?
What We Do In Life, Echoes In Eternity.... -
Another good option for firewire/USB2 combo cards is stuff build by Orange Micro.
Just to let you know you need service pack 1 installed for USB2.0 to work.
Thanx Craig Tucker I'm all set with the SP1 already. So do I need just a card with USB 2.0 & firewire or do I need one of those kits?
All you need is the card, can be bought for less than £10 here.
Why are there such wide price ranges?
http://www.newegg.com/app/ViewProduct.asp?Submit=list&catalog=73&DEPA=0&description=us...=2&listStyle=2
Im looking for a USB2.0 & firewire add-on card. What are the internal ports used for? Do I need internal ports? Also, what is ATA and what is it used for? Can You tell I bought my computer factory made. I feel like such a newb!What We Do In Life, Echoes In Eternity.... -
The internal ports can be used to connect to front connectors that are on some cases. If your case doesn't currently have front USB / Firewire connectors you would not need them.
I have 2 usb slots in front, So would a 4 port usb and 1 firewire card fit there? Are cards the same size? Also, if I do hook up these in the back of my pc, can I have on end of the usb cable connected 24/7 in the back, and the other end unconnected hanging on desk, until I need to use it?
You can hook up a cable 24/7 and have it just laying there ready for use. PC's detect the USB device being plugged in, not the cable. -
Thank you very much Jayhawk. You answered exactly what I was asking. Thanx again
No sound in WME with USB capture card
By bomb jack in forum Capturing and VCRReplies: 2Last Post: 25th Feb 2011, 03:40 -
The Best USB Tv Tuner / Card around ?
By rock_king_my in forum Capturing and VCRReplies: 1Last Post: 16th Dec 2008, 21:44 -
USB video card vs. internal
By xinjingqiao in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2008, 20:03 -
Best trouble free USB Card.
By blinky88 in forum MacReplies: 3Last Post: 3rd May 2008, 18:10 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 11:58
