my pc didn't come with firewire port, and i'm thinking about adding an aftermarket for my upcoming video editing project (using a dvcamcorder as analog capture). i'm totally clueless about firewire cards. i went to ebay and there were bunch of them that were super cheap, notably the VIA chipset. are they pretty much all the same, or is there something that i need to look for? thanks in advance...
Pretty much all the same. Check your local stores. They're cheap ~ $15-25.00 Some are combo USB2 and Firewire.
Some of those combo's are great especially if your machine only has 1.1 USB ports. I have seen those as high at $49.00 at the stores. I bought a 4 port firewire card a few months back... with cable for about $25.00
card w/ cable $10 enter coupon code 'pricewatch' for free shipping
http://www.acortech.com/.sc/ms/dd/1081989155763388/9/nc/Controller%2520Cards--Firewire...20PCI%2520CARD
i have ordered from this place a few time w/ no problems ever. -
thx for the head's up!
stupid question; if they're pretty much all the same, why the price discrepancy (number of ports, usb2/firewire combos aside)? i mean i saw a three port generic card a third of a price compared to belkin or iogear.
i just don't want to buy a super cheap one and ended up screwing my pc; or am i being too paranoid? -
w/ brand name your usually buying the name, package, software. cheaper brands usually dont have much coming w/ them, just card and standard software. thats my opinion. Im very satisfied w/ the cheap card I bought for $13 and it had software/cable.Originally Posted by Spunjer
Branded also sometimes use better chipsets like the TI chipset. I bought a cheap FireWire card for my laptop since I wasn't worried about its occasional use, but for my PCs without FireWire I bought Adaptec cards. If you see a cheap one with the TI chipset that should work fine.
While doing my research for a combo card, I found that cards with the ALI chipset were having problems. I didn't see many problems with the VIA chipset. i ended up getting a PPA combo card for $22.99
This is the card I got
http://www.ppa-usa.com/product_pages/usb/1578.htm
What do you used for a PCI xpress firewire card?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2011, 21:45 -
URGENT! Firewire card for computer
By dakota413 in forum Capturing and VCRReplies: 9Last Post: 10th Aug 2011, 18:22 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
DV Camera to DVD plus Firewire Card Help.
By Sikander in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2007, 15:35 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 10:20
