Results 1 to 11 of 11
  1. Ok, I've done some reading here and basically +R is for data burns, and -R is for video. I'm a little confused. I'm gonna be doing a lot of burnings of xvids and vcd's. Those are video files obviously, but I want to burn them as data, so does that mean I'd need +R, or will I still need to get -R instead since it is video related?
    Does it really matter which format I use? Like the disc will malfunction or something?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    NO NO and NO! The two formats are essentially the SAME. The only thing is -r is SLIGHTLY more compatible for dvd players (I can burn both and haven't had any troubles with either).
    Kevin
    P.S. Watch out for flamers!!! Here we go again!!!
  3. Member 888888's Avatar
    Jan 2004
    Turdistan
    Use DVD-R. That is the one I use.
  4. Member maek's Avatar
    Jan 2004
    Arizona
    Use DVD+R. That is the one I use.
    Seriously, though, your choice. I use DVD+R and have not come across compatibility issues. But there's nothing wrong with DVD-R, either.
  5. Banned
    Jan 2004
    Going in Circles
    The only difference that is glaring right now is that +r will burn faster, and was the first out of the gate on dual layer burning.
  6. +-...+-...+-+-+-...+-
    Hmmmm...
    Oooooo...
  7. Member maek's Avatar
    Jan 2004
    Arizona
    Yes, they both have their pluses and minuses. Ouch, stop hitting me.
    On a more technical note in support of +R, check out this website:
    http://www.cdfreaks.com/article/113
    However, your average user probably could care less. Either works fine.
    "What? Huh?!? WHAT will come out no more?!?" Jack Burton -- BIG TROUBLE IN LITTLE CHINA
    Jul 2002
    Up in yo' bitch.
    DVD+R is bad.
    DVD-R is good.
    DVD+R will leave you with a hangover and a pair of blue balls.
    DVD-R will not only massage your shoulders and feet after a long day, but will also give you a happy ending.
    Seriously... I use both... all depends on what's on sale.
  9. I have hardly run into problems using the + as opposed to - for video. I suggest you purchase the cheaper of the two if your burner supports both formats.
    I have a small l*enis
  10. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Smearbrick1, I'm glad you added that last line "seriously". Otherwise, I would have thought you were having some kind of mental breakdown.
    Kevin
    ---+R and -R are essentially the same, to stay on topic ------
  11. Latest is the greatest
    + is the latest
