Anyone using a wireless repeater? I had to move my router to the farthest room in the house, due to some remodeling. My reception is still okay, but it gets pretty sketchy on some days. I've been interested in getting a repeater, but I'm not sure if they're any good. No sense in shelling out another $70, if my signal is still going to be unstable.
Have you tried a semi-directional antenna instead of a repeater? That might buy you enough gain.Originally Posted by mrtristan
I have my router in the lower corner of my house and my internet machine is in the floor above in the other corner of the house and I still get 75% or better signal strength so I always figured repeaters were for small office or business settings, or perhaps so you could access the internet from across your yard or something. What are your signal stregth/quality going down to on that computer? I've surfed the web OK on signals around 10% without much noticeable loss. I did notice that file transfers that use the bandwidth will take longer with low signal strength, but unless you've got some fast internet you shouldn't notice the drops ever so often.
Not a repeater but this might work...Originally Posted by mrtristan
http://www.turnpoint.net/wireless/has.html
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
My signal strength varies from day to day. Some days it's just as good as when the router was upstairs, but some days it just won't hold the signal. I think I live in an area with a lot of interference. It's actually been behaving for the past week, so I might just live with it.
I've had great luck with the D-Link DWL-900AP+. It's an access point that can be used as a repeater, bridge, client, etc. Fairly expensive new but refurbed ones go for around $50.
http://www.pcbay.net/specbunkit.html
Have also heard good things about the Hawking Wireless Antenna which was on sale at Micro Center last week for $25. CompUSA has it for $30.
http://www.compusa.com/products/product_info.asp?product_code=304558&pfp=BROWSE -
Jayhawk - Thanks! I was looking at that antenna, but I wasn't sure about it's performance. It's cheaper than buying a repeater, so I was really interested in picking one up.
Hauppauge 1212 with 4 USB Active Extension Repeater cables
By mail2tom in forum Capturing and VCRReplies: 1Last Post: 22nd Mar 2010, 19:52 -
How do analog repeater stations get their signal?
By cal_tony in forum DVB / IPTVReplies: 1Last Post: 22nd Feb 2009, 12:04 -
Digital cutoff date USA for low power small repeater stations?
By cal_tony in forum DVB / IPTVReplies: 2Last Post: 28th May 2008, 10:52 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 2nd Nov 2007, 23:56 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 6th Aug 2007, 23:26
