I've had my Apex AD-1100W for less than 2 years. A couple of days ago I tried to play a dvd on it and almost as soon as a put the dvd in it immediately said, "No Disk." I tried cds and various dvds but all with the same result. Its not like it can't understand the format because these are not burned dvds. Even when it doesn't recognize the format, it takes a couple of minutes to scan the disk before declaring "no disk." Has anyone else had this problem? Does anyone have a solution?? Thanks.
Have you tried a lens cleaning yet?
I've always had intermittent situations where that particular machine can take some time to read the TOC on a DVD-RW or DVD+RW disc, but never THAT long... -
How do I perform a lense cleaning? Or would I have to try updating the firmware? If so, how can I do that?
Remove the cover and use q-tips and isopropyl alcohol and clean the lense.
Look up the 1100W in the Player section. I found this first but I remember there are others who describe the fix a lot better.Originally Posted by The DVD Player Section over to the left
Post your problem at the APEX 1100w forum site. You'll find more help there than in this forum site. Here's the link for it:How do I perform a lense cleaning? Or would I have to try updating the firmware? If so, how can I do that?
http://www.nerd-out.com/forum/viewforum.php?f=25&sid=b4bec9fafb609a65e482c51b47db3f4c
__________________________________________________ ___________
Sounds like an echo.......Originally Posted by budz"Art is making something out of nothing and selling it." - Frank Zappa
Apex DVD player AD-1100W - remotes compatibility
By Matthias in forum DVD & Blu-ray PlayersReplies: 5Last Post: 2nd Dec 2008, 14:16 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 19:23 -
Replacement for Apex AD-1500
By siskiou in forum DVD & Blu-ray PlayersReplies: 7Last Post: 30th Mar 2008, 23:59 -
Apex AD1250X Owners?
By nemesys23 in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2008, 18:36 -
Help! Apex 5131 Will Not Play DVD
By NautTboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2007, 12:33
