ok when converting .avi to dvd mpeg2 to play on my standalone dvd player, the subtitles get cut off. but i already fixed the subtitles problem in tmpgenc by setting the "video arrange method" to "Center (custom size)" and then i set the pixels and after many trail and errors i finally found the perfect size for the left,right, and bottom side of the frame. the only problem is the top isnt perfect, there's this black line about 1/2 of an inch. why is the picture off-centered? i tried many other files and i still get the same problem so that's not the case. is there a way to move the picture up a bit using tmpgenc or any other program? any help is appeciated, thanks.
Results 1 to 9 of 9
yeah, sorry, i meant the dimensions.
if you use full screen (keep aspect ratio) for 640 x 480 avi's they come out perfectly, without cutting off the subs. -
actually i tried many settings including that, and it doesnt work. most tv has overscan or whatever and it cuts the subtitles off. the only way i got close to perfecting the file i wanted is to do the custom size in tmpgenc. is there any program at all out there that lets you move the picture around?
hmm, well i convert quite a bit of anime with subs and always use center (keep aspect ratio). have never had a problem when using that setting for 640 x 480 avi's. like your tv, my tv has overscan as well and it seems to work perfect for me.
/shrug -
not all TVs are the same, others work different and i already tried what you suggested and it doesnt work. is it even possible to move the picture around? or is it possble to add a bigger black border on the bottom than the top?
there's a setting in tmpgenc that allows you to clip frame on the advanced tab.
double-click on it to adjust the borders. -
thanks for the help, but that doesnt work also.
it actually CUTs a part of the picture, then adds a black border, which is what i dont want lol. i dont want it to cut anything, all i want it to do is add a black border.
Converting HD-DVD subtitles To BLURAY subtitles
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 06:15 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 15:53 -
problem converting subtitles
By arconreef in forum SubtitleReplies: 2Last Post: 26th Nov 2010, 20:22 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10
