I've been trying to convert from VHS to DVD for the last few weeks. After many problems I decided to just pay the money for a DVD Recorder to have it done. When I went to Walmart I found that they had these VHS and DVD combo drives where the DVD was a burner. They all had a way to copy directly from the VHS to DVD. I was wondering if anyone here has encountered these things and if they had any suggestions on the best one to get. I've heard a ton about DVD recorders but don't know which of these may fall into this category where they have both in one. Also, if anyone has experience with the ones I found at Walmart I would appreciate any comments you might have. They are:
Sanyo DRW-1000
Panasonic DMR-E75E
Emerson EWR-20V40
Results 1 to 12 of 12
I use a Sansui from Sears and love it. Yes it dubs VHS to DVD however you will find that most of those tapes you bought will have copy protection which will be a waste of time dubbing from the internal VHS. I use a external VHS, fed into one of the inputs of the recorder and is fed through a Sima CT2 video enhancer. I have had no experience with the recorders from Walmart so I can not do you any good there.
Funny thing is I picked up the Sanyo to give that a shot and I've already noticed some of the tapes going jittery when capturing them. I think I'm going to look into taking it back to get a normal DVD recorder and getting a TBC or something to go between that and the VHS. The only problem with all this is that I want to be able to use the recorder to capture it and then author the DVD on my computer. The capturing part is what I've been having the most difficulty with.
Combo drives are never good. Buy a good VCR and a good DVD recorder.
I've never met a combo that I liked very much either....well....now that the Olsen twins are older....maybe....OH....wrong web site.
Seriously....combos DO suck for the most part....
I have to stop now... -
I have the Panasonic DMR-E75VS and it works fine for me. This is just a hobby for me. I am sure using the other methods will give better quality videos but for me it's fine, until it becomes more of a hobby and I start getting anal about the quality
I copy from VHS to DVD for my 3 year old and the quality, to me, looks like VHS which is what is expected. Also like stated above alot of store bought tapes have copy protection and there is no way to bypass that on a combo unit unless you use a seperate VCR. -
Originally Posted by Marvingj
Originally Posted by xiaNaixWant my help? Ask here! (not via PM!)
The JVC specs seem to suggest this.
The playback quality with some of the older S-VHS VCR's (like the JVC HR-S9600U, for example) is vastly superior to the cheap units they package in those combo DVD recorder/VCR machines. Plus, you have the potential for additional heat and repair issues with two devices in one box.
It is definitely better to invest in maximum playback and recording PQ with a separate high quality VCR and standalone DVD recorder.
Best Dvd Recorder/Vcr Combo
By rosbif08 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 9th Oct 2010, 15:52 -
DVD Recorder/VCR combo
By tj1182 in forum Capturing and VCRReplies: 4Last Post: 1st Dec 2009, 20:52 -
DVD Recorder/ VCR combo
By whitemtntn in forum DVD & Blu-ray RecordersReplies: 9Last Post: 7th Aug 2009, 21:30 -
Best DVD-Recorder/VHS Combo For The $$$???
By expat in forum DVD & Blu-ray RecordersReplies: 4Last Post: 6th Dec 2007, 09:00 -
VCR/DVD Recorder combo with TBC?
By mysabel in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jun 2007, 14:47
