hey, ive got this dvd/vcr combo unit and i have some pal files i want to burn, im having major problems converting them to ntsc so im curious as to wether or not this player will play PAL vcd/svcd/dvd etc. ive checked the compatibility, but it doesnt say about the ntsc or pal?
any help
thanks
The easiest way to convert between the two systems is via a DVD Player that actually "converts". It just so happens the cheap-ee ones are the ones that do this most often....NOT the big brand names.
It's going to be pretty hard to find a DVD Recorder that will convert one system to another while recording. And the VCR's that do a true convert are still quite expensive and quite hard to come by:
http://www.freetradephoto.com/AiwaMX-100Pal-NTSCVCRConverter.htm
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 11:15 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Philips DVDR3595H
By nvlokhov in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Dec 2007, 14:07 -
Philips DVP
By Gunstra in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Nov 2007, 12:44 -
philips dv 3120
By belairbelair in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Oct 2007, 16:44
