i am trying to play a avi clip but all i get is sound no picture...can somebody tell me how to fix this. next problem is when i try to convert my avi clip to mpeg-2 using tmpegnc it tells me it is not supported and i am not able. how would i fix this.....any help on these things would be great.
Your AVI clip is most likely in DIVX or XVID format. You need to download and install the proper codecs. The divx codecs can be found on
www.divx.com
Do a search on google to find latest xvid codecs.TANSTAAFL
avi.Net Problem: Not producing an .avi file
By Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 16:22 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 11:31 -
lagarith avi to xvid avi - problem
By phpmysql348 in forum EditingReplies: 1Last Post: 23rd May 2008, 13:15 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 10:57
