Thread: tmpgenc error
  1. when using tmpgenc via the wizard for svcd - ntsc film, i try to load my *.d2v file and im recieving cannot open, file not supported?
    not sure what steps to take as ive followed the sticky for common tmpgenc errors and done all of that and still recieve the error.
  2. Member Grimey's Avatar
    I thought .d2v is a project file ouputted by dvd2avi. you need to import the actual avi into TMPGEnc
  3. well im following a guide for pal to ntsc converrsion and this is what it says to do.
    Click on browse under video file and locate the d2v file from step 4.
    When you click OK you get a screen that looks like this, judging the field order.
    any ideas?
