How do I fix crackly knobs on my bass amp, computer speakers, and other electronics.
By "crackly knob", I mean there is an in and out, distorted and crackle noise when you turn the (usually volume) knob, or sometimes without turning it but it is in a certain position.
This problem plagues me like crazy and has made my Hartke 120 watt amp unusable. Please help.
Results 1 to 15 of 15
Probably just need cleaning. Covered well in this thread:
https://www.videohelp.com/forum/viewtopic.php?p=959289#959289 -
Oh come on...where are all the wise cracks???
I am sure that if I said that I had "crackly knobs" I would never hear the end of it.No, I'm from Iowa. I only work in outer space. -
yeah, usually cleaning. If that doesn't work, there are 3 possibilities. They are listed in the order of most likely to least likely.
1) The spaekers themselves are blown and the sound causes the coil to move in and out of alignment. (depends on the type of crackling you hear)
2) There's a short/open, fray, corrosion on a wire. (older speakers in humid environments get this once in a while)
3) The POT (potentiometer or variable resistor) is old or wearing out. (usually only hapens under extreme use of turning the knobs.) -
Originally Posted by babyboo
I've tried to get the guys to behave when you're around, babyboo. I don't want them to drive you off in disgust. On the other hand, if you haven't hit the bricks by now, chances are you may be "one of us", hee hee -
Doramius wrote:
3) The POT (potentiometer or variable resistor) is old or wearing out. (usually only hapens under extreme use of turning the knobs.)If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Shiny knob here too
Actually radio shack sells a spray for 'manual switches' that lubes the contacts. I used to use it all the time to eliminate the 'scratchies' in an old car radio I had
The crackly knobs gag was too obvious. There needed to be something a little better for a good turn out.
Here's what I got in the way of jokes.
I almost didn't check this thread thinking it was about granny-sex.
You've got crackly knobs?
Try using a lubricant or lotion. If it starts bleeding, use Neosporing as a Lubricant. You'll need a large tube.
Crackly knobs are possibly due to old age & extended use or stretched skin from being preggo or not putting down the fork.
