Hi I have some cartoons I downloaded in SVCD format. Was wondering how I go about burning them on Nero. Do I need special discs. I now use CD-R's to burn my mp3's and other formats but am assuming SVCD will not burn on these. Any help appreciated.
Michelle
you burn SVCD's on regular cd-r discs. Nero should have an option to burn SVCD, but I think you need the mpeg2 plugin (dont remember).
I think if the files are already in svcd format then you don't need the plugin, but I don't really remember either.Originally Posted by Treebeard
no you don't need it, the plugin is just for encoding to SVCD (mpeg-2)
For NERO 6 and up, open NERO (not in express mode) go RECORDER tab select BURN IMAGE select you SVCD file (typically a .bin...look with ALL FILES from the drop down box) ....in the pop up burn box select image type MODE2 (this is essential) and just burn the file...for NERO 5 BURN IMAGE is in the FILE tab.
hth
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Burning DVD+R with Nero 7
By solarblast in forum Authoring (DVD)Replies: 6Last Post: 24th Aug 2010, 06:17 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 23:04 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 09:35
