I recently downloaded a XviD file - 700MB - 2h 28mins
I used MainConcept to convert to Elementary video and audio, however, the audio stream was only 1hr long.
So I used VirtualDubMod to extract the audio as a WAV which DVD-lab reported was not suitable for DVD, so...
I tried using DVD-lab's transcode audio feature, but whenever I hit the large Transcode button it just generates a 1KB file named AUDIO_48kHz.mp2.
I have just tried Besweet and this generates the audio ten minutes short.
How can I get the audio converted correctly so I can use it in DVD-lab. I have never had a problem like this before. Help![]()
well, if the audio you got out of BeSweet was 10mins short then that's probably a wrong PAL/NTSC setting. A PAL movie has been sped up from 24 to 25 fps. On a 2 and a half hour movie I think 10mins would be about right. So try changing the setting from PAL to NTSC or vica versa...
Thanks for the reply, I never thought of that. I thought that the PAL NTSC only mattered for video.
My XviD source is PAL - 25fps. So why am I getting shortened audio.
Can someone advise me on the best course to:
RIP the audio from my XviD file and then
TRANSCODE this to DVD-compliant audio -
this is how I would work:
- rip audio: using virtualdub, also decompress the audio (audio>full processing mode compression>no compression PCM)
- encode: using tmpegenc, load dvd template, then unlock template, select 'audio only' hit start. Now you have an mp2 wich you can import in any DVD authoring software
Converting a 480x720 2:3 short to a 1280x720 16:9 HD short.
By Cyrax9 in forum MacReplies: 2Last Post: 14th Feb 2011, 17:40 -
Star Trek: TNG transcodes
By txporter in forum Video ConversionReplies: 8Last Post: 17th Dec 2010, 17:51 -
MKV, 1:37 long, audio always comes out 44 mins only..
By TheGlow in forum Video ConversionReplies: 6Last Post: 20th Apr 2009, 17:45 -
Audio and video off if captured longer then 10 mins?
By Ghtpua in forum Capturing and VCRReplies: 4Last Post: 7th May 2008, 12:39 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 03:19
