i was just wondering is it possible to rip video from a dvd in dts or 5.1 and then put it back on a dvd to play it in surround sound with dvd shrink or something and also how do you tell how many channels of audio a video file is using.
Hello,
YES YES and YES! 5.1 is the way to go. All you have to do is select the ac3 5.1 audio channel listed in the lower left panel of dvd shrink. It will rip it with the video, then when you burn it will play back in 5.1 (dolby or dts).
Use gspot to identify what your audio is in a video clip.
As yoda313 states yes it is possible to rip 5.1 channel audio.
DVD Shrink alreadys give the information on which audio track (Dolby 5.1 or DTS 5.1) the dvd contains, just check the box which audio you wish to keep.
All DVD Shrink does is compress the movie to fit on a dvdr to approx 4.37GB. the audio is untouched and is not compressed. therefore, you may find it useful that if the dvd contains both Dolby Digital and DTS audio (or maybe directors commentary), it is best to keep only one audio track, usually the Dolby audio as this is more compatible with dvd players and takes up less MB than DTS. The reason being that this will allow more room (in terms of MB) for the movie, only requiring a little compression and hence improved quality.
Hope this helps!! -
thanks, for the info. it helped a lot , im a n00b at this stuff. also i just said dvd shrink cause i had that but is that a good program to use for ripping and stuff or should i be using something else. i also have the nero suite, i think that may have some useful programs
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
each audio track on different audio channel or device
By mikedepetris in forum Software PlayingReplies: 2Last Post: 28th Nov 2009, 08:56 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47
