  1. how do you find out how many dropped frames you have,,i used vstream pvr plus for capture,and sound is several seconds out of syn,,i'm capturing from home recorded vhs tape
  2. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    Normally you'll find this information as and when you capture.
    Virtualdub, for instance, will show the frames lost as they happen, and a total when you've finished.
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  3. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Consider buying a timebase corrector (TBC) if you plan on capturing regularly from tape. I captured for several months fighting the sync problems until I bought a TBC. Now bad sync is just an unpleasant memory
