What's the best vcd hardware encoder to capture vcd compliant files?
Pinnacle MP10?
Dazzle Dvc?
Hauppauge PVR?
other?
Thanks!
A few years back, some said the Provideo PV-231 was the best VCD cap card. I tried it and was not impressed.
I cannot comment on the ones you listed. But I really believe that you should capture full frame video (720x480/576PAL or even 352x480 could work) at a high bitrate (MPEG2 or AVI) and then use software encoder to produce VCD. It is the long way, but the best results I have experienced by far!!! -
I usually capture at the best settings with my Pinnacle Mp10: 3000 kb/s bitrate, with this gop structur: IBBPBBPBBPBBPBBPBB. Then convert video eith Tmpgenc with high quality (slow) motion search precision...good results...but it's too slow...I'm searching for a video hardware capture encoder device that can encode videos directly to video cd format on the fly...
You can use Mainconcept encoder to make you video it has a realtime mpeg1-2 encoder.
USB Mpeg1 Hardware Encoder?
By leebo in forum Capturing and VCRReplies: 8Last Post: 10th Apr 2010, 00:32 -
Hardware MPEG-2 encoder cards
By cybertheque in forum Video ConversionReplies: 20Last Post: 20th Oct 2008, 20:51 -
WinTV Hardware Encoder Workflow?
By Armandoban in forum Authoring (DVD)Replies: 5Last Post: 23rd Sep 2008, 14:42 -
Best hardware mpeg2 encoder (under 700 $)?
By Speed Demon in forum Capturing and VCRReplies: 27Last Post: 6th Sep 2007, 11:01 -
Turbo.264 USB Stick Hardware Encoder
By willrob in forum MacReplies: 12Last Post: 26th Jun 2007, 00:58
