  1. Here's a question, ive got a tiny file ive made into a DVD templete with tmpeng dvd author VIDEO_TS only its 25meg, if I burnt it on a CDR i take it no dvd player would reconise it????
    DVD region settings are a joke, I can't believe how stupid people are falling for it
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    SOME will. You have to format it as a minidvd or cvd. In fact, Roxio and others have this template built in. The only problem is compatibility. Most dvd players only recognize dvd-rom as dvd (and dvd-r,+r of course). You could check out the dvd player list to see if yours will play the minidvds --
    https://www.videohelp.com/dvdplayers
    Good luck, use a cd-rw so you don't burn a coaster
    Kevin
    it is called minidvd or cdvd
    www.videohelp.com/minidvd
  4. If your DVD play will play VCD's more than likely it will also play MiniDVD's (Mine would but only on RW discs)
