I use a NEC ND-2500A with 107v2b5dld firmware patch.
The problem is when I write Ritek G04 -R 4x at 8x speed
it reads OK on my DVD-burner and DVD-rom but on my standalone Mustek v560 player the brightness of the movie varies during playing.
DVD's burnt at 4x doesn't have that problem.
Any explanation?
Originally Posted by ulapines
Ritek G04s are not rated to burn at 8X. I would assume you are seeing that this is true for a good reason. If your question has to do with why they are readable in some readers and not in others it probably has to do with better error correction.Still a few bugs in the system... -
Did you check the PI/PO rating with your disc that cannot playback with your DVD player? I am assuming this is the drive problem. Because I was an NEC user at first.
Out of Sync only on Standalone player
By sambat in forum Video ConversionReplies: 2Last Post: 1st Sep 2011, 05:15 -
HT - dvd player in the pc or a standalone?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 5Last Post: 6th May 2010, 07:39 -
best standalone DivX player?
By coyote2 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Mar 2008, 12:01 -
Mustek V56L-5E DVD player How To Reboot remove YUV P-Scan setting
By ImNoSmarterN5thGrdr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Aug 2007, 08:32 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 10:41
